钢筋混凝土简支梁非线性分析,怎么调都不收敛,求高手指点,感激不尽
浏览:83899 回答:3
下面这是命令流,拜托各位了,急。。。。。。。。。
*******************简支梁非线性分析********************
FINISH
/CLEAR
/CONFIG,NRES,2000
/PREP7
!定义单元与材料性质
ET,1,SOLID65
KEYOPT,1,1,1
KEYOPT,1,7,1
MP,EX,1,13585
MP,PRXY,1,0.2
FC=14.3
FT=1.43
TB,CONCR,1
TBDATA,,0.5,0.99,FT,-1
TB,KINH,1,,11
TBPT,,0.0002,FC*0.19
TBPT,,0.0004,FC*0.36
TBPT,,0.0006,FC*0.51
TBPT,,0.0008,FC*0.64
TBPT,,0.0010,FC*0.75
TBPT,,0.0012,FC*0.84
TBPT,,0.0014,FC*0.91
TBPT,,0.0016,FC*0.96
TBPT,,0.0018,FC*0.99
TBPT,,0.0020,FC
TBPT,,0.0033,FC
TBPLOT
ET,2,LINK8
MP,EX,2,2.0
MP,PRXY,2,0.3
TB,BISO,2
TBDATA,,300,0
PI=ACOS(-1)
R,1,0.25*PI*22*22
R,2,0.25*PI*10*10
!创建几何模型
BLC4,,,150,300,1000
WPOFF,,,50
VSBW,ALL
*DO,I,1,9
WPOFF,,,100
VSBW,ALL
*ENDDO
WPCSYS,-1
WPROTA,,,90
WPOFF,,,30
VSBW,ALL
WPOFF,,,90
VSBW,ALL
WPCSYS,-1
WPROTA,,-90
WPOFF,,,30
VSBW,ALL
WPOFF,,,240
VSBW,ALL
WPCSYS,-1
!划分钢筋网格
ELEM
LSEL,S,LOC,X,30
LSEL,R,LOC,Y,30
CM,ZJL,LINE
LATT,2,1,2
LESIZE,ALL,ELEMSIZE
LSEL,S,LOC,X,120
LSEL,R,LOC,Y,30
CM,ZJR,LINE
LATT,2,1,2
LESIZE,ALL,ELEMSIZE
LSEL,S,LOC,X,30
LSEL,R,LOC,Y,270
CM,JLL,LINE
LATT,2,2,2
LESIZE,ALL,ELEMSIZE
LSEL,S,LOC,X,120
LSEL,R,LOC,Y,270
CM,JLR,LINE
LATT,2,2,2
LESIZE,ALL,ELEMSIZE
LSEL,S,TAN1,Z,0
LSEL,R,LOC,X,30,120
LSEL,R,LOC,Y,30,270
CM,GJ,LINE
LATT,2,2,2
LESIZE,ALL,ELEMSIZE
CMSEL,S,ZJL
CMSEL,A,ZJR
CMSEL,A,JLL
CMSEL,A,JLR
CMSEL,A,GJ
LMESH,ALL
LSEL,ALL
/ESHAPE,1
EPLOT
!划分混凝土网格
VSEL,ALL
VATT,1,,1
MSHKEY,1
ESIZE,50
VMESH,ALL
ALLSEL,ALL
!施加约束和荷载
LSEL,S,LOC,Z,0
LSEL,R,LOC,Y,0
DL,ALL,,UY
DL,ALL,,UZ
LSEL,S,LOC,Z,1000
LSEL,R,LOC,Y,0
DL,ALL,,UY
ASEL,S,LOC,X,0
DA,ALL,UX
ALLSEL,ALL
P=50000
Q=P/100/150
ASEL,S,LOC,Z,450,550
ASEL,R,LOC,Y,300
SFA,ALL,1,PRES,Q
ALLSEL,ALL
!求解控制设置与求解
/SOLU
ANTYPE,0
NLGEOM,ON
NSUBST,100
OUTRES,ALL,ALL
AUTOTS,ON
NEQIT,100
CNVTOL,F,,0.05
SOLVE
!进入POST1后处理
/POST1
SET,LAST
PLDISP,1
ESEL,S,TYPE,,2
ETABLE,SAXL,LS,1
PLLS,SAXL,SAXL
ESEL,S,TYPE,,1
/DEVICE,VECTOR,ON
PLCRACK
!进入POST26后处理
/POST26
NSOL,2,534,U,Y
PROD,3,2,,,,,,-1
PROD,4,1,,,,,,P/1000
/AXLAB,X,UY
/AXLAB,Y,FY
XVAR,3
PLVAR,4
PRVAR,3,4
lafeike
ex是对的,我说错了,好像不收敛还是因为钢筋混凝土没有合理链接
2015年1月15日
lafeike
EX太小,其次钢筋混凝土怎么连接的都没有说好像,所以肯定不会收敛
2015年1月15日
