abaqus abort with system error node 309,这个该怎么解决?我是新手,真心弄不懂了
浏览:107342 回答:1
piratelxm
Abaqus JOB Job-1
Abaqus 6.10-1
C:\SIMULIA\Abaqus\6.10-1\Python\Lib\jabber.py:68: DeprecationWarning: the sha module is deprecated; use the hashlib module instead
Begin Analysis Input File Processor
12/31/14 15:45:02
Run pre.exe
12/31/14 15:45:02
Abaqus Error: The executable C:\SIMULIA\Abaqus\6.10-1\exec\pre.exe
aborted with system error code 309.
Please check the .dat, .msg, and .sta files for error messages if the files
exist. If there are no error messages and you cannot resolve the problem,
please run the command "abaqus job=support information=support" to report and
save your system information. Use the same command to run Abaqus that you
used when the problem occurred. Please contact your local Abaqus support
office and send them the input file, the file support.log which you just
created, the executable name, and the error code.
Abaqus/Analysis exited with errors
2014年12月31日
