abaqus-XFEM裂纹模拟出现的问题
浏览:18752 回答:1
我是按照一个例子一步步做下来,没得到它的结果,不知道怎么调整,求各位帮助!出现的error如下:
The maximum normal separation at failure must be greater than zero
The maximum shear separation at failure must be greater than zero for cohesive elements or surface_based cohesive behavior; otherwise, it will be assigned the same value of the maximum normal separation.
The *damage evolution option has to be specified if the *damage initiation is used
The maximum normal traction at failure must be greater than zero
The maximum principal strain at failure must be greater than zero
A material property has been defined more than once for this material
There is no material by the name aluminum
2590 elements have missing property definitions. The elements have been identified in element set ErrElemMissingSection.
Section definitions are missing or incorrect for the elements indicated above. Further processing of the input file is not possible until this input error is fixed.
Analysis Input File Processor 因出错而退出.
你的例子是从哪里找的啊 书上吗 兄弟
