ABAQUS仿真研究
浏览:12739 回答:2
求哪位大神告诉我这是怎么回事???提示的错误代码是:
The elements contained in element set ErrElemExcessDistortion-Step1 have distorted excessively.
There is only one excessively distorted element
The ratio of deformation speed to wave speed exceeds 1.0000 in at least one element. This usually indicates an error with the model definition. Additional diagnostic information may be found in the message file.
Abaqus/Explicit Analysis exited with an error - Please see the status file for possible error messages if the file exists.
scb1101011224
没有呀,快急死了!!
2015年5月8日
yangxunlei
解决了吗?我也遇到了同样的问题!
2015年5月5日
