摩擦热结构耦合出现温升问题
浏览:3591
具体问题: 在 预定义场里设置温度25度,但算完之后温度没有变化,试着将 初温改低一点(5度),则升温到8.3度,请指教!!!
Warning“There is zero HEAT FLUX everywhere in the model based on the default criterion. please check the value of the average HEAT FLUX during the current iteration to verify that the HEAT FLUX is small enough to be treated as zero. if not, please use the solution controls to reset the criterion for zero HEAT FLUX. ”
