ls-dyna运行错误问题
浏览:3091
LS-DYNA user input
ls-dyna ls971s.53450 R4.2.1 date 06/08/2009
expanding memory to 3249 material, node and element data
expanding memory to 3343 material properties
expanding memory to 376145 element data
expanding memory to 726609 gradient of damage data
expanding memory to 1228564 user control for contact interfaces
expanding memory to 1228571 for boundary cond. vectorization
expanding memory to 1258104 arbitrary element numbering input
expanding memory to 1270193 spc cards
expanding memory to 2009201 process element material data
expanding memory to 2011217 load curve data
expanding memory to 2387369 regularize time history data
contracting memory to 2387165 rigidwall definitions
expanding memory to 2704628 velocity b.c
expanding memory to 2744891 nodal constraint sets
expanding memory to 2982071 contact interfaces
expanding memory to 3324921 mass scaling with ale
expanding memory to 3440136 ALE neighboring info
expanding memory to 4953056 ALE MMG storage 1
expanding memory to 5100864 ALE MMG storage 2
expanding memory to 5657551 ALE MMG storage 3
expanding memory to 5894050 ALE multimaterial storage
expanding memory to 6041668 contact segment data 1
expanding memory to 6093532 contact segment data 2
expanding memory to 6462234 contact segment data 3
expanding memory to 6855777 contact definition
expanding memory to 6971655 rigid body
contracting memory to 6953336 contact friction
expanding memory to 6962942 rigid body b.c.
expanding memory to 7116041 joints
expanding memory to 7116063 body force loads 2
contracting memory to 7116063 shell solid interfaces
contracting memory to 7116063 accelerometers
expanding memory to 7116163 rigid bodies for disp. termination
contracting memory to 7116163 transformation to move nodes
expanding memory to 7116306 ALE fsi control block
expanding memory to 7116308 ALE fsi node and seg list
*** Error part # 0 is out-of-range
0.000E+00 0.000E+00 0.000E+00 1.000E+00 0.000E+00 0 0
input phase will continue if possible
expanding memory to 7129828 ALE fsi seg connectivity
expanding memory to 7515309 ALE fsi coupling forces
expanding memory to 7669049 void materials
contracting memory to 7669035 thermal expansion 0
expanding memory to 7669041 flexible body 2
contracting memory to 7669041 implicit joints
input phase completed with 1 fatal errors
please check messag file
E r r o r t e r m i n a t i o n
S t o r a g e a l l o c a t i o n
这个问题应该怎么解决??怎么会有PART0??
