The geometry of 1 elements is too distorted. Check the nodal
浏览:7830
abaqus出现这个错误要怎么办啊
The geometry of 1 elements is too distorted. Check the nodal coordinates or node numbering on elements identified in element set ErrElemDistorted.
19 nodes have dof on which velocity/displacement/acceleration/base motion etc. constraints are specified simultaneously. The nodes have been identified in node set ErrNodeBCRedundantDof.
Analysis Input File Processor exited with an error.
