急!Workbench13.0简单静力学分析,求解一直出错!急
浏览:3809 回答:1
网格 接触 施加力 感觉都正确,但就是最终求解 出错,错误信息如下:
An internal solution magnitude limit was exceeded. Please check your Environment for inappropriate load values or insufficient support. Also check that your mesh has more than 1 element in at least 2 directions if solid brick elements are present. Please see the Troubleshooting section of the Help System for more information.
