关于ansys批处理的问题
浏览:11337
我用命令流做了个ansys的仿真,想通过批处理得到模型图,分网图,和最后的计算结果图。用的是/SHOW,JPEG这个命令,代码如下,请问是哪里的错误导致模型图无法获取呢?请大神帮忙解答下,非常着急,谢谢大家了H=1000
n=130
r=1.2e-8
rec=42.6
dis=0.2
h1=0.6
r1=0.6
r2=2.65
r3=7
h2=9
r4=18
D1=h2+dis
D2=D1+h1
p=0.1e-8
F=100000
voltage=3
/FILNAME
/TITLE,2D eddt
/PREP7
ET,1,53,,,1
ET,2,53,2,,1
ET,3,53,1,,1
EMUNIT,MKS
MPTEMP,,,,,,,,
MMPTEMP,1,0
MP,MURX,1,1
MP,MURX,2,1
MP,RSVX,2,r
MP,MURX,3,1
MP,RSVX,3,p
/PNUM,AREA,1
RECTNG,0,r4/H,0,r4/H,
RECTNG,r1/H,r2/H,D1/H,D2/H,
RECTNG,0,r3/H,0,h2/H,
AOVLAP,all
NUMCMP,all
/REPLOT
/show,jpeg
ASEL,s,area,,1
AATT,2,1,2
ASUM
*GET,a,AREA,,AREA
*GET,xc,AREA,,CENT,X, , , ,
*SET,CF,2*3.14*r*xc*N**2/rec/a
R,1,a,n,0,1,cf,
ASEL,,,,3
AATT,1,,1
ASEL,,,,2
AATT,3,,3
ESEL,ALL
LESIZE,2,, ,12 , , , , ,1
LESIZE,1,, ,12 , , , , ,1
LESIZE,12,, ,12 , , , , ,1
LESIZE,11,, ,12 , , , , ,1
LESIZE,7,, ,50, 0.05, , , ,1
LESIZE,8,, ,40 , , , , ,1
LESIZE,4,, ,10 , , , , ,1
LESIZE,5,, ,20, , , , ,1
LESIZE,6,, ,10 , , , , ,1
LESIZE,3,, ,20 , , , , ,1
LESIZE,10,, , 50, 0.05, , , ,1
LESIZE,9,, ,, 40, , , ,1
MSHKEY,0
ASEL, , , ,3
AMESH,3
MSHKEY,1
ASEL, , , ,1
AMESH,1
ASEL, , , ,2
AMESH,2
eplot
/SHOW,JPEG
NLIST,ALL, , ,XYZ,NODE,NODE,NODEESEL,S,MAT,,2
NSLE,S
CP,1,CURR,ALL
ESEL,S,MAT,,3
NSLE,S
CP,2,VOLT,ALL
ALLSEL,ALL
NSEL,S,EXT
D,ALL,AZ,0
allsel,all
/SOLU
antype,harm
esel,s,mat,,2
bfe,all,vltg,,voltage
esel,all
harfrq,F
SOLVE
FINISH
/POST1
SET,FIRST
PLF2D,27,0,10,1
ESEL,S,MAT,,2
SET,1,LAST,1,0, , ,
PRNSOL,CURR,
/SHOW,JPEG
/show,close
