求助:划分网格失败
浏览:9944 回答:2
UG中用曲线组建的模型,转成x_t后导入workbench,在网格划分的时候总是失败,提示:The following entities failed to mesh. The meshes of the bodies containing these entities are not up-to-date. However, meshing may be successful on the other entities.和The mesher did not generate any nodes. All geometry may have been defeatured away.求教!
建议使用smrtsize试试
2015年9月12日
郭工
模型比较复杂,倒角,圆角,曲面过渡,细节比较多的情况下,会失败,推荐先进行模型简化处理
2015年9月11日
