急!!1!求助
浏览:3958
The program is unable to open file file.LN09. If the suggestions in
the associated error messages immediately preceding and/or following
this error message do not help resolve the file issue, please send the
data leading to this operation to your technical support provider,
along with the system error code of -1, for help in determining the
possible reasons as to why this file could not be opened.
是什么情况
