ABAQUS 用户子程序 错误代码529697949
浏览:18919 回答:5
1.The executable pre.exe aborted with system error code 529697949. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.2.The job "huang" has been created.
The job input file "huang.inp" has been submitted for analysis.
Error in job huang: The executable pre.exe aborted with system error code 529697949. Please check the .dat, .msg, and .sta files for error messages if the files exist. If there are no error messages and you cannot resolve the problem, please run the command "abaqus job=support information=support" to report and save your system information. Use the same command to run Abaqus that you used when the problem occurred. Please contact your local Abaqus support office and send them the input file, the file support.log which you just created, the executable name, and the error code.
Job huang aborted due to errors.
我安装的版本是ABAQUS 6.13+VS2012+IVF XE2013,使用黄永刚的INP,FOR文件验证能否运行子程序,提交作业时出现上述问题,求大神指教解决方案
我的也有这个情况,我的解决方案是删除掉除了inp的其他模型,再提交就好了,不知道你的是否这个问题。
2018年10月9日
评论 3 点赞 2
Kevin_3249
我做ABAQUS cfd耦合热传导也碰到了,应该是电脑运作内存不足或者文件输出不稳定导致的,已经解决了。可以从以下几个方法去尝试一下: 1⃣️ 并行计算使用默认的,不勾选多核计算 2⃣️使用管理员运行ABAQUS 3⃣️job里面不要修改内存使用设置 4⃣️使用虚拟内存 5️⃣ job里面的暂存文件选择一个有大一些空间的盘里面的文件夹,注意路径是英文
2024年4月21日
