『求助』用过SIMULINK中模糊控制工具箱的请进
浏览:502976 回答:2
我在SIMULINK模型中用到"Fuzzy Logic Toolbox",
然后不管我向这个模糊控制器模块输入什么信号,开始仿真后都会提示如下错误:
MinMax blocks do not accept 'boolean' signals. The input signal(s) of block 'a113/Fuzzy Logic Controller/FIS Wizard/Defuzzification1/Max (COA)' must be one of the MATLAB 'uint8', 'uint16', 'uint32', 'int8', 'int16', 'int32', 'single', or 'double' data types
请各位高手赐教,谢谢
