『求助』给转动副加上摩擦力后仿真会失败?为什么呢?
浏览:188225 回答:1
转动副加上摩擦力Joint fiction后,动力学仿真失败,出现如下提示:
WARNING: After 50 iterations of the calculations for the initial conditions, the
mechanism has been assembled with a maximum-magnitude error of 1.99113E-09
which does not satisfy the specified tolerance of 1.0E-10 .
WARNING: The corrector has not converged after 1 attempts. No. of iterations = 6.
ERROR: The simulation stopped at time = 0.0 . ADAMS cannot solve
the equations of motion.
The greatest error in an equation is 2.23534E+24 in the
equation for FRICTION model.FRICTION_4 .
The greatest change in a variable is 242.79 in the
variable for JOINT modle.JOINT_55 .
我的动力学求解参数设置是:Error:0.05;Corrector:Modified;Maxit:20请问PATTEN是什么?在那里设置?
我要怎么才能正确设置转动副摩擦力参数设置对话框中的参数?
有的地方能加摩擦力,有的地方还不能加摩擦力。
实践出真知!
