Abaqus划分网格技巧小结.pdf
2020-08-31 下载:12
- 技术邻 >
- CAE仿真 >
- 前后处理 ,
- HyperWorks ,
- Abaqus
下载
大小:523.51KB
根据英文帮助文档翻译的网格划分技巧,简单实用,易理解,希望对大家有帮助
Figure 7 A regular grid of elements cannot be created
Abaqus 中三维几何体生成扫描网格的分割方法
无法生成扫描网格的问题 分割示例
起始面和目标面必须只能是一个整面(a single face),或是四边形组成的面片组合,
四边形的面片可以生成规则网格(form a regular grid pattern)。节选段落二:
图 6 The swept meshing technique cannot mesh a part if an isolated point touches the
axis of revolution
图 7 Abaqus/CAE cannot mesh a region with hexahedral elements if one or more edges
lie along the axis of revolution
图 8 Abaqus/CAE can mesh the region with hexahedral-dominated elements
具体实例可见帮助中的 17.17.7节选段落三:
If the included angle at some
edges or vertices lies outside this range, Abaqus/CAE displays a warning and allows you to
remove those edges or vertices from your selection. If you choose to retain the sharp edges, the
resulting mesh may not lie on a smooth surface.
无法生成扫描网格的问题 分割示例
axis of revolution
