DOE的意义手册.pdf
DOE的意义手册.pdf
Therefore, it is not presented here.
________________________________________________________________________________
iSIGHT DOE Post-Processing Example
4.0 Example Post-Processing Calculations
Experimental Results
Execution of the DOE Study defined in Section 3.0 results in the following set of experimental节选段落二:
Interpretation of iSIGHT’s DOE Plots
iSIGHT provides a number of DOE-specific plots to visualize your results. This section explains
how to interpret these plots.节选段落三:
6
The Main Effect plots are essentially prediction profile plots showing how the polynomial model
that was fit to the DOE data varies between the low and high levels of each factor independently
6
查看更多评论 >
