MOLDFLOW完整分析报告.pdf
很好的参考资料!
扇形
浇口尺寸为:
25x2-8.5x5(mm)
Page 38/2002
注塑成型分析ICAX论坛提供
Manufacturer LG Chemical
Trade Name Lupoy SR-3108FL
Family Abbreviation PC
Fibers / Fillers Unfilled
Moldflow Material ID 52777
Moldflow Grade Code LK403
The material was tested by Moldflow. Data was last updated on JAN-02-2003.节选段落二:
This data is per Moldflow Plastics Labs current recommended best method for process simulation CAE. The method used applies well to
most materials and applications.
材料介绍:
由于用户未指定材料,所以采用了MOLDFLOW材料库中现有的一种PC料作为分析材料,可
能和实际不符。所以该分析结果只作为参照。节选段落三:
该材料的各项参数如下:
Page 48/2002
注塑成型分析ICAX论坛提供
THERMAL:
The material's thermal conductivity was tested by Moldflow by means of the Moldflow TC200 aparatus. Data was last updated
on 01-FEB-00. Thermal conductivity was established at a single temperature.
扇形
浇口尺寸为:
25x2-8.5x5(mm)
Page 38/2002
注塑成型分析ICAX论坛提供
材料介绍:
该材料的各项参数如下:
Page 48/2002
注塑成型分析ICAX论坛提供
THERMAL:
查看更多评论 >
