nsoft(GlyphWorks)官方培训资料.pdf
2013-04-03 评论:8 下载:44
下载
大小:3.28MB
nsoft(GlyphWorks)官方培训资料,谁还有别的的拿出来分享一下啊!
The tutorials should take about an hour each to complete and assume no prior knowledge of GlyphWorks or other
nCode products such as nSoft.
Each tutorial builds on what you learned from the previous tutorials, so you should do them in sequence.
节选段落二:
These are
illustrated in the diagrams below.
0
10
20
30
y
Amplitude PDF
Measures of Central Tendency: give an indication of the mid value in the PDF
Median: the mid value with an equal number of points above and below (11)
Mean: the average value or the centre of area of the PDF about
the x axis (
节选段落三:
12)
Mode: the value that occurs most often, or the location of the peak of the PDF (8)
0
10
20
30
y
Amplitude PDF
Measures of Spread: give an indication of the width or range of values in the PDF.
(8条)
很有用
刚入门 希望找到有效的培训教程
查看更多评论 >
