out文件.doc
2013-12-06 评论:20 下载:1
- 技术邻 >
- CAE仿真 >
- HyperWorks
下载
大小:16.47KB
这个问题怎么解决啊,附件是
Block Lanczos Eigenvalue Extraction
Current Memory (RAM) : 21275 MB
Estimated Minimum Memory (RAM) for Minimum Core Solution: 20340 MB
Recommended Memory (RAM) for Minimum Core Solution : 23143 MB
Estimated Minimum Memory (RAM) for Out节选段落二:
of Core Solution : 26684 MB
Recommended Memory (RAM) for Out of Core Solution : 30282 MB
Recommended Memory (RAM) for In-Core Solution : 204595 MB
(Note: Minimum Core Solution Process is Activated.)节选段落三:
DISK SPACE ESTIMATION INFORMATION :
Estimated Disk Space for Output Data Files : 522 MB
Estimated Scratch Disk Space for In-Core Solution : 352993 MB
Estimated Scratch Disk Space for Out of Core Solution : 559573 MB
Estimated Scratch
Estimated Scratch
查看更多评论 >
