adams常用键.pdf
这几天上传点实用的东西~ 1、adams2014 下载链接:http://pan.baidu.com/s/1dELdjpf 密码:ui8w
Keyboard Shortcuts
Overview
This appendix shows the keyboard shortcuts for ADAMS/Car.
Keyboard shortcuts are key combinations that access
commands quickly. When you enter a keyboard shortcut, the
focus must be in the main window except when entering a
keyboard shortcut that works in dialog boxes.节选段落二:
The shortcuts are organized into the following operations that
you can perform:
■ File Operations, 2
■ Edit Operations, 2
■ Display Operations, 3
■ Viewing Operations, 3
2 Building Templates in ADAMS/Car
Chapter
File Operations
Edit Operations
Table 1.节选段落三:
last operation Ctrl + z
Redo the last undone operation Ctrl- Shift + z
Copy objects Ctrl + c
Paste text in text boxes in dialog boxes and as comments Ctrl + v
Cut text from text boxes in dialog boxes Ctrl + x
Delete selected object Del
Modify object Ctrl + e
Escape operation Esc
Keyboard Shortcuts
Overview
you can perform:
Chapter
File Operations
Edit Operations
Table 1.节选段落三:
