insight.pdf
2017-03-23 下载:12
下载
大小:789.22KB
insight官网教程,英文版,当然需要更多的可以去官网下载的
Using ADAMS/Insight with ADAMS/View
Introducing the Suspension Tutorial8
ADAMS/Insight Interface
This section describes what you see when ADAMS/Insight first opens. Figure 1 shows the
main window as it appears when you first launch ADAMS/Insight.
节选段落二:
The foundation of the method involves characterizing
parameters with a Probability Density Function (PDF). This function must be specified for
each parameter that will be varied in the analysis. Examples of parameters include spring
stiffnesses, damping rates, and initial rotation rates.
节选段落三:
To start ADAMS/Insight from ADAMS/View:
1 From the Main menu in ADAMS/View, point to Simulate, point to ADAMS/Insight,
and then select Export.
2 Complete the ADAMS/Insight Export dialog box as shown below:
3 Select OK.
ADAMS/View launches ADAMS/Insight and the ADAMS/Insight main window
appears.
