GA.pdf
2006-08-27 评论:4 下载:2
下载
大小:464.15KB
电子书遗传算法
Then, you can call the online-help of the program ga by simply typing
ga -h | more
where it is suggested to pipe the output to a pager.
节选段落二:
Internal GA-Options [an]: The special options which are passed to the
GA. These options are described in the section \Further Options" (see
4.2.3).
节选段落三:
is automatically produced
by the \report" program after a run of the GA.
(4条)
ooooooooooooooooooooooooook
查看更多评论 >
