HyperMesh-Fluent.pdf
2006-12-13 评论:5 下载:16
下载
大小:75.21KB
HyperMesh-Fluent
Altair Engineering
HyperMesh - Fluent
This document describes two approaches to generate 3D mesh files for Fluent, using
either HMASCII or NASTRAN files.节选段落二:
Use the NASTRAN format to import directly into
FLUENT, and the HMASCII format if you want to use TGrid to export a mesh for
FLUENT.
• First export an hmascii or nastran file containing only 3D linear elements (tets,
hexas, piramids, pentas) and the associated 2D elements for all the subsets of
the boundary节选段落三:
Note: in the export panel, make sure that "displayed" is
selected, so that only the displayed collectors will be saved to the HMASCII
file.
• Start TGrid (mesh generator that comes with Fluent), and select
File=>Import=>Hypermesh Ascii=>Volume, a file selector comes up, change
Files of Type to All
Altair Engineering
HyperMesh - Fluent
FLUENT.
the boundary节选段落三:
file.
查看更多评论 >
