教程例题十二--(压力容器)Pressure Vessel PVDesigner Model.doc
压力容器方面例题
Pressure Vessel PV/Designer Model(压力容器)
Objective: This tutorial will step through the creation of a pressure vessel using PV/Designer.
Features Illustrated:
· Using PV/Designer
Problem Description
· A 3-D plate model of the pressure vessel shown below will be constructed using PV/Designer. 节选段落二:
· The pressure vessel will have one nozzle along the main cylinder.
· One end of the cylinder will have an ellipsoidal head with an ellipse ratio of 2.
· One end of the cylinder will have a spherical head with a nozzle.
· Each nozzle has the following properties:
· Length of 24 inches.
· Diameter of节选段落三:
24 inches.
· 8-inch wide repad at the intersection with the vessel.
· 6-inch wide flange at the end.
1.选择“文件/新建”命令。
· Using PV/Designer
Problem Description
· Diameter of节选段落三:
24 inches.
1.选择“文件/新建”命令。
查看更多评论 >
