deform模拟过程中断
浏览:81947 回答:1
在模拟deform模拟时,老是自己停止,请教高手帮忙指导,提示: INFO: End of Simulation for Run# 2
FEM MESSAGE:
1st Contact Normal = -1.00000E+00 0.00000E+00 0.00000E+00
2nd Contact Normal = 1.00000E+00 0.00000E+00 0.00000E+00
Error : Conflict in normal directions of two contact surfaces
Object No = 1 Node No = 390
Object No = 1 Node No = 443
1st Contact Normal = 0.00000E+00 1.00000E+00 0.00000E+00
2nd Contact Normal = 0.00000E+00 -1.00000E+00 0.00000E+00
Ending time is:Sun Oct 12 19:25:12
*** INFO: Simulation Module Indicates End of Simulation
*** INFO: End of Automatic Remeshing Run -- Bye###
Total Number of Runs = 2
风儿
错误:两个接触面在法向干涉
物体1,在390节点处x法向
物体1,在443节点处y法向
我想可能是你的边界条件没设对吧
2008年10月13日
