也来贡献一下:how-to-model-single-wheels
浏览:25662 回答:1
SIMPACK is able to model wheel sets (where the wheels are interconnected by an arbor
transmitting torques) as well as single or independent wheels without this arbor. The modelling
concept, whether or not the wheels are connected by this arbor, is nearly the same.
We define „single wheels“ as two wheels situated on a shared axle or a similar mounting, but
without any torque transmission. On the other hand, „independent wheels“ are mounted on two
different devices which can move independently:
aa00616
这就是建立独立轮转向架的步骤啊,谢谢分享
2012年4月12日
