abaqus 运行时,出现以下警告,然后计算很快就就结束了,但是没有计算结果,不知道该怎么办?
浏览:92221 回答:4
abaqus 运行时,出现以下警告,然后计算就就结束了for *tie pair (assembly_pickedsurf114-assembly_pickedsurf141), adjusted nodes with small adjustments were not printed. Specify *preprint, model=yes for complete printout.for *tie pair (assembly_pickedsurf114-assembly_pickedsurf141), adjusted nodes with small adjustments were not printed. Specify *preprint, model=yes for complete printout.for *tie pair (assembly_pickedsurf114-assembly_pickedsurf141), adjusted nodes with small adjustments were not printed. Specify *preprint, model=yes for complete printout.for *tie pair (assembly_pickedsurf114-assembly_pickedsurf141), adjusted nodes with small adjustments were not printed. Specify *preprint, model=yes for complete printout.没有结果,该怎么办啊?请各位大侠帮忙!
补充一下:在这个分析步里面还定义接触,部分面在接触和约束里面都用到了
这个不是没有结果的原因。你自己在检查下dat,msg和log文件,里面应该有出错提示的。
