在ADAMS中用柔性体替换刚性体
浏览:44893 回答:1
在ADAMS中用柔性体替换刚性体后仿真时出现:WARNING: The distance between the J marker and the I marker is 5.2043372154.
(No warnings if less than +/-1.0E-003)
Fixed Joint = .model_1.JOINT_3
I Marker = .model_1.PART5.MARKER_5
J Marker = .model_1.PART15_flex.MARKER_6
WARNING: The markers for JOINT model_1.JOINT_3 are not initially coincident.
The relative displacement between the markers, expressed in the
J marker coordinate frame is:
Delta X = 1.4066 Delta Y = 0.74948 Delta Z = -4.9543.
有高手知道这是怎么回事?
有高手知道这是怎么回事?
