用HyperMesh前处理,导出到Ls-Dyna,计算出现的Error
浏览:172919 回答:4
*** Error segment normals sum to zero at interface
node number 2343671 check segment orientation.
related to this node.
node number 2367105 check segment orientation.
node number 2434354 check segment orientation.
node number 2434464 check segment orientation.
请大侠帮忙看看,如何解决,谢谢!
请大侠帮忙看看,如何解决,谢谢!
