error:solution not converged at time 6.25e-02,run teminated
浏览:143044 回答:6
这是错误文件
error :"solution not converged at time 6.25e-02(load step1 substep1) run teminated"
这种错误怎么处理啊?是什么引起的?
紧接着还有个错误 “The unconverged solution (identified as time 1 substep 999999) is
output for analysis debug purposes. Results should not be used for
any other purpose. ”
求教大神,这应该怎么处理啊?
这种错误怎么处理啊?是什么引起的?
求教大神,这应该怎么处理啊?
楼主解决了吗,我也遇到同样的问题。
