求助:在adams2010仿真truck出现以下错误,怎么解决?谢谢!
浏览:66980 回答:1
Reading in property files...
Reading of property files completed.
Setting up the vehicle assembly for Driving Machine maneuver...
Setup of vehicle assembly completed.
Simulation is beginning...
Starting analysis #1 of vehicle assembly...
* MSC.Software Corporation *
* A d a m s *
* Automatic Dynamic Analysis of Mechanical Systems *
* A d a m s / S o l v e r *
* (Build: 2010.1.19.37) *
* 2012-10-31 19:53:36 Version MD 2010 *
* Customer Entitlement ID: C67C3660-A4AAD8B1 *
Enter ADAMS model file name or Carriage Return or ? (or STOP):
No model input file (ADM file) is given.
Enter Command:
file/model=wer_ilc
A new model supplied. Initialization starts...
The default input and analysis values will be restored.
CPU time used = 0.82812 seconds
Enter ADAMS output file name or ? (default is same as input):
Adams model file .. wer_ilc.adm
Default file names for output files
Tabular output file:
wer_ilc.out
Diagnostic file :
wer_ilc.msg
Message Database file :
wer_ilc.mdb
Graphics file :
wer_ilc.gra
Request file :
wer_ilc.req
Results file :
wer_ilc.res
Input Phase - Reading in Model
Adams/Solver dataset Title:
Adams/Car Assembly (MD Adams 2010)
Reading of model complete.
Adams/Car MD Adams 2010
Processing ENVIRONMENT entries in 'D:\chengxu\adams2010\acar/acar.cfg'
Processing ENVIRONMENT entries in 'C:\Documents and Settings\Administrator/.acar.cfg'
Processing ENVIRONMENT entries in 'D:\chengxu\adams2010\atruck/atruck.cfg'
Adams/Tire
Version MD Adams 2010
Input Phase - Populating Solver database
---- ERROR ----
***** ADAMS MEMORY OVERFLOW *****
A larger LD array is required.
The error occurred in subroutine "TVREQ" while allocating "CHAR" space
for the "Routine".
Space Available: 0 Space Requested: 1
Adams/Solver requires more program memory to run this model.
Be aware that the above figures for Space available and Space
requested only reflect the current requirements. Additional space
may be required later in the solution process.
Several off-the-shelf memory configurations are available and
custom configurations may be created. The available memory models
and the corresponding array sizes are:
NAME LCEXPR LDSIZ
STANDARD 100 2,000
LARGE 200 2,000
EX-LARGE 300 5,000
HUGE 1000 50,000
where the columns correspond to:
LCEXPR : Maximum number of lines in a Function
LDSIZ : Maximum total number of lines in all Functions
To use an alternative setting, you have to start the Adams 'Settings'
program. It can be found using the Start menu:
Start -> Programs -> MSC.Software -> Adams -> Adams-Settings
Solver Memory Model Settings
Current Model ---- Standard
Main numerical data array (MDSIZ) ---- 1100000
Overflow space Main array (OSSIZ) ---- 100000
Character word data array (CDSIZ) ---- 4000
Main Character array (LDSIZ) ---- 2000
Max length an expression (LCEXPR) ---- 100
Max number of constants (FPSIZE) ---- 250
Max levels of func nesting(MXSTAK) ---- 50
Max RPN instructions (NINSIZ) ---- 1000
Terminating Adams/Car usersubs...
Adams/Solver execution terminated by subprogram LSPACE
CPU time used = 1.6562 seconds
ERROR: A lookup operation was still in progress when AMD was shut down.
ERROR: Error type: ae_lookup_unfinished
ERROR: Parent name: .wer_ilc
ERROR: Parent type: ao_model
ERROR: Search type: ao_request
ERROR: Cannot load results! File 'wer_ilc.res' not found.
ERROR: Cannot load graphics! File 'wer_ilc.gra' not found.
Simulation is complete.
lpqing518
到底怎么仿真 对truck 急求解?????
2013年4月24日
