求助:ANSYS中建立通电螺线管3D模型的电磁场分析
浏览:182898
我在通过
ANSYS建立电磁场模型的过程中遇到了一些问题,希望大家能帮我解决,我建立的磁芯是一个立方体,采用solid96,线圈采用sourc36,我根据一个三维螺线管的例子修改的代码如下:
/batch list
/prep7
/title, 3-D Static Force Problem - Tetrahedral
/com,
! define analysis parameters
n=1500! coil turns
i=1! current per turn
!define element type
et,1,96
!define material properties for air and steel
mp,murx,1,1
mp,murx,2,100
!create pole volumes
/pnum,volu
!create armature and air volumes and compress numbers
block,0,25,0,25,-25,25! armature
block,0,26,0,26,-26,26! air region
vovlap,1,2
numcmp,volu
sphere,0,500,0,90
vovlap,all
numcmp,volu
!set volume attributes
vsel,s,volu,,1
vatt,2,1,1! armature
!mesh the model
allsel,all
smrt,6! for production work a finer mesh should be used, (LVL 6)
mshape,1,3d
mshkey,0
vmesh,all
/pnum,mat,1
/number,1
eplot
!scale the model to meters
allsel,all
vlscale,all,,,.001,.001,.001,,0,1
!create the coil
race,.0265,.0265,.001,n*i,.001,.048,,,'coil1'
/eshape,1
eplot
save
finish
!apply boundary conditions
/solu
d,2,mag,0
!solve
allsel,all
magsolv,3,,,,,1
finish
我通过这个代码没有得到比较理想的结果,大家能不能帮我看看有什么问题?
我通过main menu/general postproc/plot results/contour plot/nodal solu查看磁场强度,发现网格化的尺寸不同(代码里用了6),磁场强度的有很大差异,不知道是什么原因?
原来的代码中在磁芯外建立了一个很薄的空间场,之后又建立了一个大的空间场,这个很薄的空间场好像对网格划分有影响,我想问一下这个空间场建立的机理是什么?
/batch list
/prep7
/com,
n=1500! coil turns
et,1,96
mp,murx,1,1
mp,murx,2,100
/pnum,volu
vovlap,1,2
numcmp,volu
sphere,0,500,0,90
vovlap,all
numcmp,volu
vsel,s,volu,,1
!mesh the model
allsel,all
mshape,1,3d
mshkey,0
vmesh,all
/pnum,mat,1
/number,1
eplot
allsel,all
!create the coil
/eshape,1
eplot
save
finish
/solu
d,2,mag,0
!solve
allsel,all
magsolv,3,,,,,1
finish
