求助:hypermesh中的error
浏览:60228 回答:1
*** Warning load curve 17 x-axis reverses direction
Check that this curve is correct
*** Error repeated points in load curve number= 17 point number= 11
*** Error repeated points in load curve number= 17 point number= 12
expanding memory to 14700826 rigidwall definitions
expanding memory to 15082795 nodal constaint sets
beinsnow
载荷曲线17中有重复点。。。可以查看点11和点12看看。。。
2013年5月9日
