ansys用sparse和PCG求解器都出错且没结果
浏览:43784 回答:3
我用ansys中的sparse 求解器求解一个300万网格的非线性接触模型(结构分析),没有结果,报出的警告和错误如下:
*** ERROR *** CP = 2083.643 TIME= 03:07:15
The program is unable to open file gjjiechumx1.LN09. If the suggestions in the associated error messages immediately preceding and/or following this error message do not help resolve the file issue, please send the data leading to this operation to your technical support provider, along with the system error code of -1, for help in determining the possible reasons as to why this file could not be opened.
0***** process error reported by subroutine xdslfa
see xdslfa abstract (ier = -505)
*** ERROR *** CP = 2083.643 TIME= 03:07:17
Input/output error on unit = 9. Please check to see if the disk is full.
可我的磁盘是NTFS格式,且还有150G可用(网格是映射与自由网格组成),这是怎么回事呢?
而换为PCG求解器后错误如下:Preconditioned conjugate gradient solver error level 1. Possibly, the model is unconstrained or additional iterations may be needed. Try running with a multiplier MULT > 1 in EQSLV command (3 > MULT > 1).
请哪位大牛帮帮忙解答一下上诉的两个问题。先说声谢谢了!
duyan1990
网格数量太多,电脑配置不够,减少网格数量就行啦
2014年4月2日
一诺千城2013
也是这个问题啊,求教高手!
2014年3月27日
duyan1990
我也出现了类似的问题,请问你是怎么解决的,谢谢
2014年2月28日
