deform运行时会停止,求指点,弄了好几天了
浏览:176018 回答:2
我做的是球盘式磨损实验,主要是下面两个问题
(1)Info: Program skipped over iterations due to rigid mode.
*** INFO: Substepping due to DPLEN at Node 225 of Obj. 1
Old time step = 0.89981D+03; New time step = 0.69226D-03
2)Info: Program skipped over iterations due to rigid mode.
cfnCUBE_Get_Elem_Conn: the bucket of object(201) and entity data set (1) does not exist
cfnCUBE_Get_Object_NI: the bucket of object(201) and entity data set (1) does not exist
cfnCUBE_Get_Object_ER: the bucket of object(201) and entity data set (1) does not exist
请大家帮帮我!
Nouveau
虽然十年过去了,但今天我碰到这个问题任然不会解答,有大佬帮助否?
2023年11月27日
lvshiliang
因为The two constraints overlap for Node 25201,模拟停止了
求高人指点
怎么解决
2013年5月19日
