Workbench导入复杂装配体后Mesh问题
浏览:107989 回答:3
Workbench导入复杂装配体后,全部选中然后右键form new part 形成一个大的多体部件体(目前不知应该怎么处理更能符合实际装配环境,望高手指教)进入Model按照默认划分网格generate mesh 后出现两个error。怎么处理才能不出现错误报警,顺利Mesh,请各位大侠不吝赐教呀,不胜感激!
1 the following surfaces cannot be meshed with acceptable quality.try using a different element size or virtual topology.
2 a mesh could not be generated using the current meshing options and settings. hint:the problem geometry areas might have been highlighted.
如果忽略这两个错误继续加载约束、载荷等求解,能否得到应力应变云图?
