橡胶非线性分析警告
浏览:182770 回答:3
左边刚体固定,分析步一:右边的刚体一个向左的位移,分析步二:给橡胶圈上半部分一个10mpa的压力计算出现如下警告,请问如何解决。谢谢!
Path based tracking is defined in contact pair (assembly__pickedsurf9,assembly_axis-1_rigidsurface_). Path based tracking cannot be used with analytical rigid master surfaces, the state based tracking algorithm will be used instead.
Path based tracking is defined in contact pair (assembly__pickedsurf21,assembly_part-5-1_rigidsurface_). Path based tracking cannot be used with analytical rigid master surfaces, the state based tracking algorithm will be used instead.
There are 3 unconnected regions in the model.
Excessive distortion at a total of 1 integration points in solid (continuum) elements
Convergence judged unlikely. Increment will be attempted again with a time increment of 2.50000e-02
威斯布鲁波少
请问解决了吗,我也有类似的问题,想跟您交流一下
2019年8月1日
yeshuwa
检查一下Boudanry的定义。
step2完了之后,在step3中,建议加:*Boundary,Fixxed
2013年6月1日
xia012358
刚体约束有问题,接触定义有问题,分析步的时间设置过大吧
2013年5月28日
