ls-dyna 求高手指点碰撞分析
浏览:36343 回答:1
每次做完前处理,生成K文件,但总是不能生成D3plot文件,已经困扰我两个月了,求高手指导。
Date: 06/04/2013 Time: 16:26:30
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version: 970 Date: 01/10/2005 |
| Revision: 5434a Time: 18:01:01 |
| Features enabled in this version: |
| ANSYS Database format |
| Shared Memory Parallel |
| Licensed to: |
| Platform : |
| OS Level : WINDOWS XP |
| Hostname : PC-201201160118 |
| Precision : Single precision (I4R4) |
| Unauthorized use infringes LSTC copyrights |
Input file: F:\ansys\chongji.k
The native file format : 32-bit small endian
Memory size from command line: 100000000
expanding memory to 100000000
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Explicit Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2005 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 277848
expanding memory to 535696
expanding memory to 639982
expanding memory to 1827298
expanding memory to 1857298
expanding memory to 1917298
expanding memory to 1948316
expanding memory to 2009816
expanding memory to 2030216
*** Error line number 80310 contains improperly formatted data
(This is line# 80310 of file
F:\ansys\chongji.k)
--------------------------------------------------------------line# 80310 ------
*** Error reading *DATABASE_BINARY_D3DUMP
expanding memory to 2565123
expanding memory to 2597885
expanding memory to 3756582
*** Error input data failed with: 1 errors
E r r o r t e r m i n a t i o n
Memory required for explicit solution : 0
Additional dynamically allocated memory: 0
Total: 0
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 0
NLQ used/max 96/ 96
Start time 06/04/2013 16:26:30
End time 06/04/2013 16:26:32
Elapsed time 2 seconds ( 0 hours 0 minutes 2 seconds)
| www.lstc.com |
| Licensed to: |
| Platform : |
* results. *
F:\ansys\chongji.k)
Total: 0
Problem cycle = 0
Number of CPU's 0
NLQ used/max 96/ 96
80310行是什么东东 仔细检查一下。
