- 技术邻 >
- CAE仿真 >
- HyperWorks
弹簧单元属性
浏览:66659 回答:2
求问 PELAS 属性里面的K GE 和S分别代表啥,按照帮助菜单写的
我推断K就是弹性系数,但是S不知道咋么理解? F = k * (u1 – u2)这个公式是胡克定律, s = S * F,但这个公式就不知道作何解释了……,求高人前来解惑!!!!!
| 2. | One or two elastic spring properties may be defined on a single entry. |
| 3. | To obtain the damping coefficient GE, multiply the critical damping ratio, |
| 4. | If PARAM, W4 is not specified, GE is ignored in transient analysis. |
| 5. | The element force of a spring is calculated from the equation: F = k * (u1 – u2), where k is the stiffness coefficient for the scalar element and u1 is the displacement of the first degree-of-freedom listed on the CELAS entry. Element stresses are calculated from the equation: s = S * F, where S is the stress coefficient as defined above. |
