ansys怎么查看接触单元和目标单元的外法线方向?
浏览:75378
谢谢。。可以附图的麻烦附上图。。谢谢!这个问题不解决,没办法往下边进行。*** NOTE *** CP = 30.217 TIME= 16:38:59 Deformable-deformable contact pair identified by real constant set 21
and contact element type 6 has been set up.
Contact algorithm: Augmented Lagrange method
Contact detection at: Gauss integration point
Default contact stiffness factor FKN 1.0000
The resulting contact stiffness 0.21667E+09
Default penetration tolerance factor FTOLN 0.10000
The resulting penetration tolerance 0.12000
Frictionless contact pair is defined
Update contact stiffness at each iteration
Average contact surface length 4.0000
Average contact pair depth 1.2000
Default pinball region factor PINB 1.0000
The resulting pinball region 1.2000
*WARNING*: Initial penetration is included.
No contact was detected for this contact pair.
*** WARNING *** CP = 30.217 TIME= 16:38:59
All selected contact pairs are initially open. Rigid body motion can
occur. You may use auto CNOF/ICONT by setting KEYOPT(5) to close
small gaps.
1 CONTACT PAIR IS SELECTED
CONTACT PAIR HAVING REAL ID = 21 IS INITIALLY OPEN
这是接触向导里边的接触状态的结果。。应该是接触单元和目标单元的外法线没有
相对。。高手指点下!!不胜感激。。
small gaps.
相对。。高手指点下!!不胜感激。。
