求问 如何定义切削仿真中的“温度自由度”
浏览:104980
Thermal contact has been defined between the surfaces ASSEMBLY_CHIP-BOT and ASSEMBLY_JOINT-TOP, but no temperature degrees of freedom associated with the surface ASSEMBLY_CHIP-BOT.这是什么意思,如何定义?急 谢谢啦!
