电磁场仿真的错误
浏览:22869 回答:2
用ANSYS Workbench做电磁场仿真,过程都设置好了,但是最后结果却出现系统找不到指定的路径的错误,请问该怎么解决,谢谢.
An Error Occurred While Starting the ANSYS Solver Module
To get further information on what the issue may be, insert a Solution Information object under Solution in the tree, and view the contents.
Possible reasons that the ANSYS solver may fail are:
  • Insufficient memory - You may not have enough virtual memory assigned to your system. To increase the allocation of virtual memory (total paging file size), go to Settings> Control Panel> System (on your Windows Start Menu). Click the Advanced tab and then click Performance Options. Increase the size of your virtual memory.
  • Insufficient disk space - You may not have enough disk space to support the increase in virtual memory and the temporary files that are created in the analysis. Be sure you have enough disk space or move to an area where you have enough.
  • Corrupt product installation
  • License request rejected
  • 这个错误,还是无法解决
xujianjun4000
楼主难道看不懂英文吗?
2013年11月19日
晴博
第一条:你的内存不足了
第二条:你的硬盘不足了
2013年11月16日
