静力分析错误 求助?
浏览:49620 回答:2
*** OptiStruct defaults set from:
install config file: d:\Altair\hw10.0/hwsolvers/hwsolver.cfg
NOTE # 1929
Created RAM scratch area: total size 200 MB.
*** ERROR # 1237 ***
CQUAD4 element number 1 references
a missing or invalid property number 3.
CQUAD4 element number 2 references
CQUAD4 element number 3 references
CQUAD4 element number 4 references
CQUAD4 element number 5 references
CQUAD4 element number 6 references
CQUAD4 element number 7 references
CQUAD4 element number 8 references
CQUAD4 element number 9 references
CQUAD4 element number 10 references
CQUAD4 element number 11 references
CQUAD4 element number 12 references
CQUAD4 element number 13 references
CQUAD4 element number 14 references
CQUAD4 element number 15 references
CQUAD4 element number 16 references
CQUAD4 element number 17 references
CQUAD4 element number 18 references
CQUAD4 element number 19 references
*** More of ERROR messages # 1237 were suppressed...
*** WARNING 1932: PSHEAR 3 is not referenced.
Error # 14 appeared total of 1104 times.
*** ERROR # 14 ***
1104 errors found in the input data.
RESOURCE USAGE INFORMATION
MAXIMUM MEMORY USED 203 MB
THIS INCLUDES 200 MB RAMDISK AREA ALLOCATED IN MEMORY
MAXIMUM DISK SPACE USED 0 MB
COMPUTE TIME INFORMATION
EXECUTION STARTED Sun Nov 03 21:59:25 2013
EXECUTION COMPLETED Sun Nov 03 21:59:25 2013
ELAPSED TIME 00:00:00
CPU TIME 00:00:00
*** PROGRAM STOPPED: FATAL ERROR(s) ENCOUNTERED.
***** END OF REPORT *****
For Useful OptiStruct Tips and Tricks, go to the URL:
http://www.altairhyperworks.com/tips.aspx
Following error/warning messages appeared too many times
and were suppressed:
1237
Total of 1085 repeat error message(s) were suppressed.
To see more messages use "MSGLMT" control card in the data or config file.
There were 1104 error messages during input processing.
The first message is repeated below:
lansexingxi
是放这些四边形的组件没有设置prop,或者prop类型设置错误,本来应该是type 应该是shell ,却选成solid,一般情况下是没有设置prop即材料特性造成的错误。
2013年11月4日
younshion
可能你的property3没有设置好参数吧 看下你的材料和壳单元的厚度T赋值了吗
2013年11月3日
