悬架KC分析时出错求好心人解答
浏览:61710 回答:6
小弟初学,对这些问题完全是蒙的,不知如何下手,请高手们帮帮忙,感激不尽!!!错误代码如下
acar_2012.1.1/acm_cmat
**** Error:
Compliance matrix calculation failed.
acar_2012.1.1/acm_rmvdof
**** Error:
Singular submatrix - unable to remove DOF's
One of the DOF's may already have zero
compliance.
acar_2012.1.1/ac_sdm_prop
**** Error:
Failure to remove the steering travel dof from the suspension compliance mat
ISTAT = 1
acar_2012.1.1/FVSA
*** Warning:
The left vertical deflection compliance terms are equal to zero.
Therefore, the front view swing arm angle will equal zero.
acar_2012.1.1/FVSA
*** Warning:
The right vertical deflection compliance terms are equal to zero.
acar_2012.1.1/asfvsl
*** Warning:
The left side rotation is equal to zero.
Therefore, the front view swing arm length will equal zero.
*** Warning:
The right side rotation is equal to zero.
acar_2012.1.1/assvsa
*** Warning:
Therefore, the side view swing arm angle will equal zero.
*** Warning:
acar_2012.1.1/svsl
*** Warning:
the left side rotation is equal to zero.
therefore, the side view swing arm length will equal zero.
acar_2012.1.1/svsl
*** Warning:
the right side rotation is equal to zero.
acar_2012.1.1/RIDE
**** Error:
Therefore, the suspension ride rate will equal zero.
acar_2012.1.1/RIDE
**** Error:
acar_2012.1.1/ROLL
**** Error:
The vertical deflection compliance terms are equal to zero.
Therefore, the suspension roll rate will equal zero.
acar_2012.1.1/acc_rid_ste
**** Error:
The left wheel ride stiffness is too large
to compute the ride steer. The ride steer
is undefined.
**** Error:
The right wheel ride stiffness is too large
is undefined.
acar_2012.1.1/acc_rol_cen
**** Error:
Unable to calculate the roll center because:
the left contact patch is constrained.
the right contact patch is constrained.
**** Error:
**** Error:
compliance.
**** Error:
ISTAT = 1
acar_2012.1.1/FVSA
*** Warning:
acar_2012.1.1/FVSA
*** Warning:
*** Warning:
*** Warning:
*** Warning:
*** Warning:
acar_2012.1.1/svsl
*** Warning:
acar_2012.1.1/svsl
*** Warning:
acar_2012.1.1/RIDE
**** Error:
acar_2012.1.1/RIDE
**** Error:
acar_2012.1.1/ROLL
**** Error:
**** Error:
is undefined.
**** Error:
is undefined.
**** Error:
A牛🐮哥
