- 技术邻 >
- CAE仿真 >
- HyperWorks
hypermesh #7007错误
浏览:112634 回答:10
用Hypermesh做静力分析时,把材料,属性,约束,载荷,工况,都弄好了,计算的时候出现下面错误警告:
ERROR # 7007 ***
The run failed because automatic memory expansion has
failed.
Currently allocated working storage is 2124 MB.
Automatic
expansion failed to expand to 2296 MB.
The failed amount is the minimum
required memory to complete the run.
Please verify whether the system has
enough memory. If it has, then please
try this run with the fixed memory
allocation to avoid a probable limitation
on the maximum locatable memory
with the automatic memory allocation.我表示我的电脑内存是16G的,怎么会内存不足呢???求高手指教!!!!急!!!!!
failed.
Automatic
我就是通过建立刚性连接,将约束传递给模型上的节点,这样约束成功了,然后就可以了。
