messag里面出现的错误信息,怎么更改,求教~
浏览:52313 回答:5
(5)
lidashen
结构规模太大 内存不足
2015年1月2日
飘着的雪
请问这个问题解决了吗?我最近也碰到这个问题,求指教
2014年12月29日
史爱民
是不是内存设置小了啊?内存改大试试。
2014年6月6日
Zain_Liu
*** Error Memory is set 6897568 words short
Current memory size 20000000
Increase the memory size by one of the following
where #### is the number of words requested:
1) On the command line set - memory=####
2) In the input file define memory with *KEYWORD
i.e., *KEYWORD #### or *KEYWORD memory=####
2014年6月5日
Zain_Liu
Date: 05/26/2014 Time: 21:08:56
___________________________________________________
| Livermore Software Technology Corporation |
| 7374 Las Positas Road |
| Livermore, CA 94551 |
| Tel: (925) 449-2500 Fax: (925) 449-2507 |
| www.lstc.com |
|_________________________________________________|
| LS-DYNA, A Program for Nonlinear Dynamic |
| Analysis of Structures in Three Dimensions |
| Version : ls971s R4.2 Date: 02/04/2009 |
| Revision: 50638 Time: 07:58:32 |
| Features enabled in this version: |
| Shared Memory Parallel |
| ANSYS Database format |
| ANSYS License (ans110) |
| Licensed to: |
| Platform : PC WINX64 |
| OS Level : SP1 B7601P/SRV 2003 X64 |
| Compiler : Intel Fortran Compiler 10.1 |
| Hostname : PC201403251821 |
| Precision : Single precision (I4R4) |
| Product ID : 50777 |
| Unauthorized use infringes LSTC copyrights |
Input file: Lfei1.k
The native file format : 32-bit small endian
Memory size from default : 20000000
expanding memory to 20000000 starting ls-dyna
******** notice ******** notice ******** notice ********
* This is the LS-DYNA Finite Element code. *
* Neither LSTC nor the authors assume any responsibility for *
* the validity, accuracy, or applicability of any results *
* obtained from this system. The user must verify his own *
* results. *
* LSTC endeavors to make the LS-DYNA code as complete, *
* accurate and easy to use as possible. *
* Suggestions and comments are welcomed. Please report any *
* errors encountered in either the documentation or results *
* immediately to LSTC through your site focus. *
* Copyright (C) 1990-2009 *
* by Livermore Software Technology Corp. (LSTC) *
* All rights reserved *
contracting memory to 1 beginning of keyword reader
expanding memory to 21002
expanding memory to 312426
expanding memory to 3115692
expanding memory to 3145692
expanding memory to 3205692
expanding memory to 3831717
expanding memory to 4448665
expanding memory to 4472162
expanding memory to 4493262
expanding memory to 4513262
expanding memory to 4533262
expanding memory to 4553262
expanding memory to 4573262
expanding memory to 4593262
expanding memory to 4613262
expanding memory to 4633262
expanding memory to 4689146
expanding memory to 4736630
expanding memory to 6010010
expanding memory to 6057494
expanding memory to 8815760
expanding memory to 8863244
expanding memory to 8885484
expanding memory to 8907484
expanding memory to 8952789
Memory required to process keyword : 8952789
contracting memory to 1 end of keyword reader
LS-DYNA will perform a structural only analysis
LS-DYNA user input
ls-dyna ls971s.50638 R4.2 date 02/04/2009
expanding memory to 2625 material, node and element data
expanding memory to 2706 material properties
expanding memory to 1735809 element data
expanding memory to 1841956 gradient of damage data
expanding memory to 4140617 user control for contact interfaces
expanding memory to 4140621 for boundary cond. vectorization
contracting memory to 4140597 nodal data
expanding memory to 4293834 arbitrary element numbering input
contracting memory to 4215039 spc cards
expanding memory to 7475586 process element material data
expanding memory to 7477587 load curve data
contracting memory to 7475788 regularize time history data
contracting memory to 7475788 rigidwall definitions
expanding memory to 7530041 nodal constraint sets
expanding memory to 8755508 contact interfaces
expanding memory to 10229609 mass scaling with ale
expanding memory to 10372061 ALE neighboring info
expanding memory to 26897568 ALE multimaterial storage
T i m i n g i n f o r m a t i o n
CPU(seconds) %CPU Clock(seconds) %Clock
Initialization ....... 0.0000E+00 0.00 0.0000E+00 0.00
Element processing ... 0.0000E+00 0.00 0.0000E+00 0.00
Binary databases ..... 0.0000E+00 0.00 0.0000E+00 0.00
ASCII database ....... 0.0000E+00 0.00 0.0000E+00 0.00
Contact algorithm .... 0.0000E+00 0.00 0.0000E+00 0.00
Contact entities ..... 0.0000E+00 0.00 0.0000E+00 0.00
Rigid bodies ......... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Nonlinear ... 0.0000E+00 0.00 0.0000E+00 0.00
Implicit Lin. Alg. ... 0.0000E+00 0.00 0.0000E+00 0.00
T o t a l s 0.0000E+00 0.00 0.0000E+00 0.00
Problem time = 0.0000E+00
Problem cycle = 0
Total CPU time = 0 seconds ( 0 hours 0 minutes 0 seconds)
CPU time per zone cycle = 0 nanoseconds
Clock time per zone cycle= 0 nanoseconds
Number of CPU's 1
NLQ used/max 136/ 136
Start time 05/26/2014 21:08:56
End time 05/26/2014 21:09:00
Elapsed time 4 seconds( 0 hours 0 min. 4 sec.) for 0 cycles
E r r o r t e r m i n a t i o n
2014年6月5日
