技术邻 > CAE仿真 > Ansys 菜鸟求助:为什么我建的模型加载不了z轴方向的电流 浏览:130641 回答:10 我建的一个波导丝的模型,分网和之前不同的是用了vsbw命令,但是结果就是出不来 ,可以加载x、y方向的电流,却加不了z轴方向的电流,求哪位大神帮忙解决一下,不甚感激
你好,能不能帮我看一下下面的这个命令流有什么问题,老是运行出错,谢谢啊
/TITLE,3DD
KEYW,MAGNOD,1
/PREP7
ET,1,SOLID97,0
ET,2,SOLID97,3
ET,3,SOLID97,1,0
MP,MURX,1,1
MP,MURX,2,1
MP,RSVX,2,1.724E-8
MP,MURX,3,100
MP,RSVX,3,2E-7
TUBE_L=300/1000
TUBE_R=5/1000
COIL_E_N=1000
COIL_E_L=20/1000
COIL_E_R_IN=15/1000
COIL_E_R_OUT=20/1000
COIL_E_T=COIL_E_R_OUT-COIL_E_R_IN
COIL_E_AREA=COIL_E_T*COIL_E_L
COIL_D_N=200
COIL_D_L=20/1000
COIL_D_R_IN=7.5/1000
COIL_D_R_OUT=10/1000
COIL_D_T=COIL_D_R_OUT-COIL_D_R_IN
COIL_D_AREA=COIL_D_T*COIL_D_L
AIR_R=60/1000
AIR_L=200/1000
PI=3.1415926
P=1.724E-8
COIL_E_RES=50
R,1,COIL_E_AREA,COIL_E_N,PI*(COIL_E_R_OUT**2-COIL_E_R_IN**2)*COIL_E_L,0,1,0
RMORE,1,2*PI*P*(COIL_E_R_OUT+COIL_E_R_IN)/2*(COIL_E_N**2)/(COIL_E_AREA*COIL_E_RES)
R,2,COIL_D_AREA,COIL_D_N,PI*(COIL_D_R_OUT**2-COIL_D_R_IN**2)*COIL_D_L,0,1,0
RMORE,1,PI*((0.1/1000/2)**2)*COIL_D_N/COIL_D_AREA
LOCAL,11,1,0,0,0,,,,1,1,
LOCAL,12,1,0,0.011,0,,,,1,1,
WPCSYS,-1,0
CSYS,0
CYLIND,TUBE_R,0,0,0.2,0,360
BLOCK,-0.01,0.01,0.0035,0.005,0.0995,0.1005
VSBV,1,2
NUMCMP,ALL
WPCSYS,-1,11
CSYS,11
CYLIND,COIL_E_R_OUT,COIL_E_R_IN,0,0.2,0,360
CYLIND,COIL_D_R_OUT,COIL_D_R_IN,0,0.2,0,360
WPCSYS,-1,0
CSYS,0
CYLIND,AIR_R,0,0,0.2,0,360
ALLSEL,ALL
VOVLAP,ALL
NUMCMP,ALL
/PNUM,VOLU,1
VSEL,S,VOLU,,1
VSEL,A,VOLU,,7
VSEL,A,VOLU,,9
VSEL,A,VOLU,,18
VSEL,A,VOLU,,28
VATT,3,1,3,0
VSEL,S,VOLU,,4
VATT,2,1,2,11
VSEL,S,VOLU,,21
VATT,2,2,2,11
VSEL,S,VOLU,,2
VSEL,A,VOLU,,3
VSEL,A,VOLU,,5
VSEL,A,VOLU,,6
VSEL,A,VOLU,,8
VSEL,A,VOLU,,10
VSEL,A,VOLU,,11
VSEL,A,VOLU,,12
VSEL,A,VOLU,,13
VSEL,A,VOLU,,14
VSEL,A,VOLU,,15
VSEL,A,VOLU,,16
VSEL,A,VOLU,,17
VSEL,A,VOLU,,19
VSEL,A,VOLU,,20
VSEL,A,VOLU,,22
VSEL,A,VOLU,,23
VSEL,A,VOLU,,24
VSEL,A,VOLU,,25
VSEL,A,VOLU,,26
VSEL,A,VOLU,,27
VSEL,A,VOLU,,29
VSEL,A,VOLU,,30
VATT,1,1,1,0
/PNUM,MAT,1
ALLSEL,ALL
VSEL,S,VOLU,,2
VSEL,A,VOLU,,3
VSEL,A,VOLU,,5
VSEL,A,VOLU,,6
VSEL,A,VOLU,,8
VSEL,A,VOLU,,10
VSEL,A,VOLU,,11
VSEL,A,VOLU,,12
VSEL,A,VOLU,,13
VSEL,A,VOLU,,14
VSEL,A,VOLU,,15
VSEL,A,VOLU,,16
VSEL,A,VOLU,,17
VSEL,A,VOLU,,19
VSEL,A,VOLU,,20
VSEL,A,VOLU,,22
VSEL,A,VOLU,,23
VSEL,A,VOLU,,24
VSEL,A,VOLU,,25
VSEL,A,VOLU,,26
VSEL,A,VOLU,,27
VSEL,A,VOLU,,29
VSWEEP,ALL
VSEL,S,VOLU,,1
VSEL,A,VOLU,,4
VSEL,A,VOLU,,7
VSEL,A,VOLU,,9
VSEL,A,VOLU,,18
VSEL,A,VOLU,,21
VSEL,A,VOLU,,28
VSEL,A,VOLU,,30
SMARTSIZE,3
MSHAPE,1,3D
MSHKEY,0
VMESH,ALL
FINISH
/PREP7
CSYS,0
N,100000,0.08,0.02,0.1
N,100001,0.08,-0.02,0.1
R,2,0,800,0.00005,0.0001,0.0001,0.0023
RMORE,0.005
ET,4,CIRCU124,4,2
TYPE,4
REAL,2
N,100002,0.08,0,0.1
E,100000,100001,100002
R,3,1
ET,5,CIRCU124,5,0
TYPE,5
REAL,3
E,100000,100001,618
NSEL,S,NODE,,100001
D,100001,VOLT,0
ALLSEL,ALL
N,100003,0.1,0.02,0.1
N,100004,0.1,-0.02,0.1
R,4,10
ET,6,CIRCU124,0,0
TYPE,6,
REAL,4
E,100003,100004
R,5,1
ET,7,CIRCU124,5,0
TYPE,7
REAL,5
E,100003,100004,1348
NSEL,S,NODE,,100004
D,100004,VOLT,0
ALLSEL,ALL
FINISH
/SOLU
ANTYP,TRANS
TRNOPT,FULL
CSYS,0
VSEL,S,VOLU,,2
ESLV,S
NSLV,S
CP,1,CURR,ALL
CP,2,EMF,ALL
CM,COIL_E,ELEM
VSEL,S,VOLU,,3
ESLV,S
NSLV,S
CP,3,CURR,ALL
CP,4,EMF,ALL
CM,COIL_D,ELEM
ALLSEL,ALL
ASEL,S,EXT
DA,ALL,ASYM
ALLSEL,ALL
ASEL,S,,,2
ASEL,A,,,1
NSLA,S,1
CP,5,VOLT,ALL
D,ALL,VOLT,0
ALLSEL,ALL
OUTRES,ALL,ALL
TIME,0.012
DELTIM,0.00002
SOLVE
FINISH
/POST26
NSOL,4,1348,CURR,,COIL_D_CURRENT
PLVAR,4
SAVE,3dd
