Workbench 疲劳分析请教
浏览:37889 回答:2
在Workbench疲劳寿命分析时,有一个参数是强度因子 Fatigue Strength Factor ,大小用来区分分析的零件与被试件的区别,有没有具体的定量参考标准。被试件的形状是长啥样的啊?:Q 比如什么样形状的结构具体应该选多大的强度因子?
Spinach
Fatigue Strength Factor (Kf )
This is the fatigue strength reduction factor. The stress-life or strain-life curve(s) are adjusted by this factor when the fatigue analysis is run. This setting is used to account for a "real world" environment that may be harsher than a rigidly-controlled laboratory environment in which the data was collected. Common fatigue strength reduction factors to account for such things as surface finish can be found in design handbooks.
查找设计手册。疲劳的问题也可以去疲劳版块讨论。
2014年8月12日
buaagfj
那零件疲劳分析时参数该怎么定呢?
2014年8月12日
