在help里面看到;Used to preserve geometric features within the selection; if the break angle between the normals of adjacent surface edges exceeds the set value, the edges will not be suppressed. 用来保持选中部分的几何特征,如果相连两平面的法向量的夹角大于这个break angle的值,就不会形成压缩边 默认的都是30°
