adamscar问题求帮助
浏览:16316 回答:1
---- START: ERROR ----
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was model.BMW_front_suspension.bgr_strut_upr.field Comp = 3 Error = 396111.236620
The variable receiving the largest increment was model.BMW_front_suspension.gel_tripot Comp = 5 Delta = 980665.000000.
这是哪里出问题了,求好心人指点!!
任bling
静平衡仿真没过
2023年12月8日
